Just like the title says "virtual dj won't quit" I have to force quit. I'm using snow leopard with the latest VDJ application installed anyone else with this problem?
geposted Fri 24 Dec 10 @ 2:20 pm
Reboot.
geposted Sat 25 Dec 10 @ 8:25 pm
djmagicmoments wrote :
Reboot.
I tried and I reset the PRAM and nothing I also reset the VDJ program and still nada
geposted Mon 27 Dec 10 @ 6:46 am
hmm... uninstall and reinstall.
I had the same problem a while ago and either rebooted or reinstalled to get it to work right. Sorry, I don't quite remember what worked.
geposted Mon 27 Dec 10 @ 10:00 am
Thanks bro the reinstall worked :)
geposted Mon 27 Dec 10 @ 10:04 am
Great...!
Sorry I didn't remember the fix right away.
geposted Tue 28 Dec 10 @ 10:30 am
I had the same problem - Mac OS 10.5.8 and Virtual DJ Pro 7. Kept having to force quit but once I re-installed, the application will quit normally. Thanks.
geposted Thu 07 Apr 11 @ 8:05 pm
