So i got the mixtrack pro with vdj-le, i can hear the music in my headphones but not through my speakers, i am using computer speakers and an external dock, someone plz help
Thanks!
Thanks!
geposted Sat 25 Dec 10 @ 12:04 am
You need to plug a pair of amplified speakers into the outputs on the back of the MixTrack.
Alternatively, plug a cable (2x RCA to 3.5" headphone jack) from the outputs on the back of the MixTrack to the line input of your computer's sound card.
geposted Sat 25 Dec 10 @ 2:03 pm
Hi, you can have it playing through the laptop speakers if you got to control panel, then to you mixtrack pro, and mute or turn off the sound card then it will come through your laptop speakers/soundcard. Hope this was helpfull.
Also i have been having a problem of my own, im sure im just being an idiot, my volume faders aren't having an affect on the sound but i can see it is moving the ones on the screen. also i can only have one song playing at the same time-the song that has the CUE cirlce lit (the PHL on the screen). Any help from anyone would be great. thanks
geposted Sat 25 Dec 10 @ 3:32 pm
I am having the same problem with the faders, and master level sliders not working. I tried reinstalling the software several times with no luck. I am in dire need of help with this issue as well. The unit was working great for a while, then stopped.
geposted Wed 12 Jan 11 @ 10:49 am
Yo chuckham. Are you still having the same problem with ur crossfade? u kno when only the cued song plays.
i found out why it does this,. to fix it, move you cue mix to the center.
geposted Fri 26 Aug 11 @ 5:45 pm
