Hey guys so today i got a numark mixtrack pro with included virtual dj le software, once i installed the software, when i click on it to access it virtual dj loads then an error message reading Invalid skin file (error line 0 in the xml) appears, any help please?
geposted Sat 25 Dec 10 @ 8:14 am
The most common cause of this error is installing the software while logged in as one user (E.g: Fred) and then trying to run it as a different user (E.g: Joe.)
The other user is missing the My Documents\VirtualDJ folder. The program will not run without this.
To resolve, please either:
(1) Install the software as the user you will be running it as.
(2) Manually copy the My Documents\VirtualDJ folder across to the other user.
Another cause is installing the software without administrator privileges under Vista or Windows 7. Right-click on the VirtualDJ installation file and choose Run as administrator. Also, we would recommend turning off UAC in Windows Vista and 7: http://www.howtogeek.com/howto/windows-vista/disable-user-account-control-uac-the-easy-way-on-windows-vista
geposted Sat 25 Dec 10 @ 2:31 pm
I am using a Mac and the same skin error pops up. I am the admin and I have the updates. What could be the issue?
geposted Thu 08 Sep 11 @ 4:11 pm
