Forum: Old versions
Topic: NEW LAPTOP CAN I SWITCH MY PROGRAMS?
So i bought a new laptop and an external hard drive. is there any way i can transfer my virtual dj pro program from my old laptop to my new one? by the way i bought the downloadable version not the physical cd.
thank you
geposted Sat 25 Dec 10 @ 1:23 pm
You are a registered user, so you can retrieve your serial number and download your software again at any time by simply going to the Download Center:
https://virtualdj.com/download/updates.html
NOTE: The End User License Agreement (EULA) allows you to have the software installed on up to two computers at any one time, providing that they are both for your own personal use and will not be used simultaneously (E.g: Second installation as a backup or for practising at home is OK, allowing a friend or another DJ to use it is NOT allowed.)
You may also uninstall the software from an old computer and then install it onto a new computer.
NOTE: If you intend to sell, give away or dispose of an old computer, you must remove VirtualDJ from it first.
