So i just got VirtualDj Pro. i cant download any of the samples here, :/ any help on making my own?
geposted Sat 25 Dec 10 @ 9:03 pm
Well if you want to make drum loops just make sure you bpm's are correct first!! That is the most important step. 2, set your loop (2,4,8,16,32) then just hit the "REC" button. Now you should see your sample in the first sample slot..........next right click on the bullseye below the sample play button, there youll see a window pop up. From there you can name and save your sample.
Hope that helps
Huey
Hope that helps
Huey
geposted Tue 28 Dec 10 @ 5:17 am
Samples and other add-ons can only be downloaded by registered licensed users who have purchased the software.
Please register your Pro serial number on the page: https://virtualdj.com/users/edit.html
Or purchase VirtualDJ Pro from https://virtualdj.com/buy/
geposted Thu 30 Dec 10 @ 7:30 am
IM HAVING THE SAME PROBLEM AND I HAVE BOUGHT THE SOFTWARE... IM USING A MACBOOK.... IM TRYING TO CREATE SAMPLES AND IT SAVES THEM, THEY WORK, BUT ONCE I TURN OFF MY LAPTOP AND GO BACK TO THE PROGRAM I CAN SEE WHAT I CREATED IN THE SAMPLER BUT IT WONT LOAD THEM... THEY SHOW UP AS A BLANK PAGE....
geposted Sun 20 Feb 11 @ 1:09 pm
Did you save the sample?
If not, then it will be lost when you close the program.
To save, click on the bullet button at the top-right of the sample slot and choose the option to save.
geposted Sun 20 Feb 11 @ 2:20 pm
