Hey Guys,
I seem to be having a problem with the loop button mappings in Virtual DJ with the Numark Stealth Control. From what I understand, Loop In should set the start point of the loop and Loop Out should set the end point of the loop and also cancel the loop during a song. Instead what's happening is Loop In will start the loop, but I need to press Loop In again to set the end point and then a third time to cancel it! If I press Loop Out at any stage it returns the song to the beginning or to a cue point.
I'm using the default mappings that Virtual DJ picked up when I plugged in the controller (everything else seems to be working perfectly) so I'm hoping this is an easy fix problem. Although I am just a beginner and could be doing the wrong thing!
Any help would be appreciated :)
geposted Sun 26 Dec 10 @ 4:07 am
