I have a 13in macbook pro and a numark mixtrack pro. When I connect my controller and open vdj le, I cannot get any sound to come out of my computer. Sound plays when I use the vdj home edition but when a track plays in vdj le no sound comes out of my computer speakers! Any ideas? Thanks!
geposted Sun 26 Dec 10 @ 10:26 pm
In your settings, what does your sound setup look like?
geposted Sun 26 Dec 10 @ 10:32 pm
sound settings for VDJ? I went in to vdj preferences, then sound set up. Input:none, Output:one, Soundcard:numark. Or were you talking about something else?
geposted Sun 26 Dec 10 @ 10:40 pm
I was talking about the VDJ settings. Just wanted to hear what you had there. Sounds like your config is good. I don't use the Mixtrack, but I looked at Numark's website and it says you don't need any additional drivers because it's class compliant. I would try to reinstall VDJ to see if that helps.
geposted Sun 26 Dec 10 @ 11:09 pm
