Hello guys.
I got the Numark Mixtrack Pro for christmas. It comes with Virtual DJ LE.
I have followed all the instructions on how to install it.
I have used it once for around an hour when I got it.
However, I went to go on it again and the controller is not working at all with Virtual DJ.
I downloaded the latest update for the controller and that did not work.
So I am quite confused as to what is wrong with the controller or the software.
If someone can help me with fixing this problem then it would be great.
Thanks,
Connor
Thanks,
Connor
geposted Mon 27 Dec 10 @ 12:43 pm
EU COMPREI UMA NUMARK MIXTRACK E SÓ CONCEGUI ISTALAR NO VIRTUAL PRO 7 E AS TECLAS FICARAN ERRADAS BASS MID E TREBLE FUNCIONAO COMO LOOP
geposted Mon 27 Dec 10 @ 2:37 pm
Sorry I can only understand english :/
geposted Mon 27 Dec 10 @ 2:48 pm
I just got one for christmas too bro...if you have a guitar center near you take it to them with your laptop, and they can help you with any problems you have. I had a similar problem and they fixed it, and showed me how to use the program within 30mins.
Good Luck,
John
Good Luck,
John
geposted Fri 07 Jan 11 @ 8:37 pm
