In VDJ, Is there any way to change High, Mid, Bass EQ frequency (Eg. change bass to 40hz to enhance deep bass) ?. Also how do i set a Shortcut key to Enable/disable my hercules jogwheels.
geposted Tue 28 Dec 10 @ 8:34 am
As far as I am aware you can't change VDJ's eq frequency's easily. What you could look at is using a VST Effects pluggin that could give you parametric eq for each deck and then set that as required. You can also buy external eq equipment to set this up.
Daz
Daz
geposted Wed 29 Dec 10 @ 1:55 am
