Recently I have changed from using my desktop to a laptop, there is an issue when I load a track by dragging the song onto the turntable... usually I'm in a hurry to start cueing up so I take my finger of the mouse pad and start mixing, When I go back the change the track on the other deck the mouse is still on the virtual platter and the song skips... Is there anyway to deactivate touching the platter but still be able to see it?
Cheers
Andrew
Cheers
Andrew
geposted Tue 28 Dec 10 @ 9:41 am
Yes there is a way. You have to edit the xml file of your skin.
Whick skin are you using and in what resolution?
geposted Tue 28 Dec 10 @ 8:46 pm
I use the standard vdj 7 2 decks 1280 x 768
geposted Wed 29 Dec 10 @ 6:51 am
Ok, unzip the VirtualdJ Pro (2decks) zip file to a folder. Edit the 1280X768 xml file with Notepad.
Search for "scratch"
You will find 2 of them one for deck 1 and one for deck 2
like this..
<scratch deck="1">
<size width="137" height="137"/>
<pos x="309" y="225"/>
<mousemask x="273" y="2533"/>
</scratch>
Delete both these 2 sections, save and rezip. Place the zip file back to its place.
Done.
like this..
<scratch deck="1">
</scratch>
Done.
geposted Wed 29 Dec 10 @ 8:58 am
nice one, thanks for the advice :) will get back to you when I try it
geposted Mon 03 Jan 11 @ 9:38 am
