Hey guys just wondering is this amp any good??
http://www.thomann.de/ie/tamp_ta600_endstufe.htm
Thanks
Thanks
geposted Tue 28 Dec 10 @ 10:15 am
all depends on what your planning on using it for mate...very little power in this as it says when running 8ohm speakers ect you only get 200watt and at 4ohm you get 300watt....
and at 309€ you could probably get better spec at around same price
geposted Tue 28 Dec 10 @ 12:04 pm
ya true my amp at the mo is screwed so id say il av to spend a bit more for a quality one.. thanks staffy lad
geposted Tue 28 Dec 10 @ 12:54 pm
Before you buy any amp, first find out how much your speakers can handle in RMs and also the peak. Once you know what they can handle, then it would be easier to determine what amp is good enough to power the speakers. A very good amp that you can buy on Ebay is a QSC Plx amp. The 1602, 2402, 3002 or 3402 series amps.
geposted Tue 28 Dec 10 @ 6:02 pm
Good call from Caliente. QSC amps are well worth a look.
As you might have noticed.The amp you were looking at is also prety heavy (14Kg). Modern digital amps produce more power for less in the lugging department. QSC,CROWN and a number of other manufacturers will provide you with an amp that chucks out a thousand watts and comes in at under 10Kg. Worth thinking about for a mobile guy.
Daz
Daz
geposted Wed 29 Dec 10 @ 1:09 am
