I just bought the newest version of VDJ, I was previously running 5.0.2 with the jp boogis mapper for my denon hc4500. I loved how that was mapped, and I would like to make some adjustments to the current mapping, but I need some help. All I'm looking to do is to assign effects to the 3 effect keys on the controller. I found a place where I could make effect button 1 give me a drop down of the different effects and effect button 2 could activate the effect, but I would like to make button one activate a brake, button two activate flange, etc..
Any advice would be appreciated
geposted Tue 28 Dec 10 @ 7:13 pm
For the first FX button assign as
effect select "brake" & effect active
For the second
effect select "flanger" & effect active
and so on.
Change the names of the FXs as you desire.
For the second
and so on.
geposted Tue 28 Dec 10 @ 9:11 pm
worked great, thanks!
geposted Tue 28 Dec 10 @ 9:29 pm
I would like to map various keys on the 4500. is there a list i could obtain with explanations? Web or print etc..........
geposted Wed 13 Jul 11 @ 9:36 pm
In this page https://virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html
you can have all the informations you need.
In case you need something particular we would be glad to help.
geposted Wed 13 Jul 11 @ 9:42 pm
thanks
geposted Wed 31 Aug 11 @ 4:16 pm
I tryed using the drop down config for assigning fx keys just does not want to work??
geposted Wed 31 Aug 11 @ 4:17 pm
