A friend of mine has v7.02 pro and I just bought the Vestax Spin controller for him to use with it.
We can't get audio out of the damn thing. I've read on here you need to set aggregate audio on his MacBook which is great advice...but how? I've followed the tutorial on the Apple site but if we launch VDJ, go into audio setup, choose external mixer, then 4-out card it only gives us the option for SPIN...we can get audio out of deck 1 but nothing out of deck 2.
Any ideas?
Any ideas?
geposted Wed 29 Dec 10 @ 1:52 am
Ahh right sorry, figured it out...think "outside of the box"!
Set it for single output and it all works fine...
geposted Wed 29 Dec 10 @ 1:54 am
They should be able to use it as follows:
Inputs: None
Outputs: Headphones
Sound card: 4-out card -> Choose Spin in the drop-down list
If it does not work, check that it is configured in MacOS for 4 channel output:
* Open the Utilities folder inside your Applications folder. Double-click on Audio MIDI Setup.
* In the Properties for: drop-down, choose the Spin.
* In the Audio Output section, choose 4ch-16 bit.
Inputs: None
Outputs: Headphones
geposted Thu 30 Dec 10 @ 6:41 am
