OK, let's try this again because I tried to edit the other thread and didn't see how to edit my original post.
How do I embed a vimeo video?
If you click the link to watch the video, you'll hear/see that when I pull the record back and hold it, the song will sometimes jump ahead in the software. The record in the software is jumping back n forth randomly, just as it sounds it is. I've followed all the setup instructions on here and everything works. This is the only thing that's kinda weird.
Any ideas what might be causing this? I've tried a powered hub, no hub, different USB ports, latest mapper, all with no effect.
PC Win7 64bit
6G RAM
1G Video RAM
VDJ 7.0.2
http://vimeo.com/18278396
PC Win7 64bit
6G RAM
1G Video RAM
VDJ 7.0.2
geposted Wed 29 Dec 10 @ 7:48 pm
Brian, are you using them in Midi mode or midi hybrid. If not the latter, you should really give that a try.
Rusty
Rusty
geposted Wed 29 Dec 10 @ 10:34 pm
OK, updated 3700's firmware and set to hybrid mode, but now the 3700s are not showing up as the sound card in the ASIO control panel. Does hybrid mode require an external sound card?
geposted Thu 30 Dec 10 @ 7:40 am
