I'm also having a problem with the VMS4 playing the VDJ Pro on the same channel. Even if the assign knobs are on different channels, it still seems to play both decks on the same channel. Then my crossfader stopped working. When it's on the left, it'll play both decks, and shut the music OFF when the crossfader is on the right side. I know I probably set it up incorrectly due to my excitement when I got my new toy, but please, someone, help me fix this. My new toy is no fun if it doesn't work properly. I followed the Quick Set-up guide that came with the VMS4 but it still isn't working right. My hardware also seems to be opposite from my software. If I load a track on the right side, I would control it on my VMS4's left side. The "normal-reverse" knob only controls the crossfaders output into my headphones. How do I fix this too? I need my software to MATCH my hardware...HELP!!!
geposted Wed 29 Dec 10 @ 11:49 pm
inside the box you will find a paper booklet with instructions on it. READ THEM you def didn't because you would have read how to set it up. you probably have the fader select set wrong. i'm sure you didn't even check the audio setup in the sound setup for the vms4 within VDJ. try those things first.
geposted Thu 30 Dec 10 @ 5:39 am
geposted Thu 30 Dec 10 @ 8:33 am
