Hello I have been using VDJ for a while now and I'm about to get turntables =D. But anyways lets say I'm at a party and someone requests a song that I don't have (take into consideration I don't have the bought version, I have home.) So, I'm at the part and someone requests a song, I don't have it. So, I pop over to Itunes and buy it. But, it doesn't show that I have the song on my VDJ program unless I close it and re open it. Is there anyway to fix it? Thanks!
geposted Fri 31 Dec 10 @ 1:55 pm
Right click on the iTunes folder and select "Recurse." At least that's what I think it is. Just right click on the iTunes folder and select the obvious choice.
geposted Mon 03 Jan 11 @ 4:34 pm
i wondered what that recurse thingy was for.
geposted Mon 03 Jan 11 @ 5:19 pm
yep, you just refresh the library, its that easy. Also, minimizing the iTunes directory and re-maximizing it should work too.
geposted Tue 04 Jan 11 @ 7:00 am
you know, i have an itunes account and have only just realised even though i sold my ipad to pay the rent i still have a use for it. reinstall here we go.
geposted Tue 04 Jan 11 @ 7:24 am
Simply drag it in, done.
geposted Tue 04 Jan 11 @ 9:25 am
yeah you can always drag the file from windows explorer or finder, then drop it into vdj on whatever deck you want
geposted Tue 04 Jan 11 @ 8:54 pm
