I have virtual dj LE and i was wondering if you can change the tempo of the song, not the speed.
geposted Fri 31 Dec 10 @ 5:20 pm
If the MIDI controller that it came with has a keylock or master tempo button then this is possible.
You may also find this feature on the VirtualDJ LE skin (Usually a padlock symbol labelled 'KEY LOCK')
geposted Fri 31 Dec 10 @ 6:21 pm
