can someone please tell me either how to put new skins on virtual dj for mac or tell me why it cant be done... i have been reading up alot on how to do this and know one seems to have an answer...
why int virtual dj helping us get this fixed..... help meeeeee
josh
josh
geposted Sat 01 Jan 11 @ 12:16 am
almost all the skins comes in 2 versions PC O MAC,just download it install it and to change the skin in virtualdj just clik on the configuration, click skins, and choose the one you want.
geposted Sat 01 Jan 11 @ 12:25 am
yeah done all that but it just doesnt appear when i open the program, grrrrrrrrr
geposted Sat 01 Jan 11 @ 12:33 am
i don't have a mac, but i think this is the way should be done
1.- download the skin it's a .zip file
2.- put that file in the folder of skins..to do this go to applications -Virtualdj-skins
3.-then open virtualdj
4.- go to the configuations tab
5.- then go to skins tab
6.- the skin should be there
i hope that helps.. like i said i don't own a mac .. but i think that's the way it works..
geposted Sat 01 Jan 11 @ 12:56 am
yeah just tried that still no luck though :(
geposted Sat 01 Jan 11 @ 1:59 am
too bad it didn't work .there is a forum exclusively for mac users you could ask them, they probably will help you better
geposted Sat 01 Jan 11 @ 10:30 am
geposted Sat 01 Jan 11 @ 10:31 am
When I used the mac version it used to "unpack" the zip files in MacOS automatically which screwed it up.
Use these settings to stop MacOS unzipping these downloads so you can place them directly in the skins folder.
Open Safari
Open the Preferences menu:
In Mac OS X: Click Safari > Preferences
In Windows: Click Edit or Settings () > Preferences
In the window that opens, click General
Remove the check from the box beside "Open 'safe' files after downloading"
Download the file again
Keith
Open Safari
Keith
geposted Sat 01 Jan 11 @ 10:34 am
