Everytime I play a song the pitch sliders start moving by themselves. I have gone through heaps of tweaking and cannot seem to fix it! Am running VDJ Pro 7 and it only happens playing through timecodes. All help appriciated, thanks
geposted Sat 01 Jan 11 @ 4:38 pm
I've had this problem & haven't managed to fix it yet but it doesn't seem to happen if you're in Absolute mode, so try that as a temp fix until anyone else has a better answer.
geposted Thu 06 Jan 11 @ 2:37 pm
That didn't work, but got it sorted just restored to factory settings
geposted Thu 06 Jan 11 @ 2:41 pm
I had the same problem, and fixed it by switching the decoder thing in Timecode Config to VirtualDJ CD or Record. Have it playing and scroll down the options until you find one that is really stable. Hope this helps!
geposted Thu 06 Jan 11 @ 9:08 pm
I get the same prob
Every time i get the best in the pitch moves
There must be a way on truning this off
PLEASE HELP!!!!!!!!!!!!!!!!!!!
geposted Fri 11 Feb 11 @ 3:09 am
I think your referring to pitch drift, I'm told there are many variables, the quality of your Timecode, CD or Turntable, quality of your needle, counterweight issues, heat-warped record. I haven't found a fix, so i use relative mode, and in advanced controls I disable pitch. (when using VDJ, in serato i have no pitch drift issues)
geposted Mon 14 Feb 11 @ 9:03 pm
