I just wanted to ask if it is possible to programme a 2 deck skin as 4 deck skin,
or if a switch function can be used ?
....as I want to use this with my DN-MC6000.
I have an own skin, that only works as 2 deck skin.
https://virtualdj.com/addons/11154/CDJ-400___DJM-700.html
geposted Sun 02 Jan 11 @ 3:30 pm
if its a "own" skin as in one you made i dont see why not. if you have 4 inputs then surely all you would need is to build in a switch button. so it switches inputs but uses the same skin. you would have to programme it to allow any already playing tracks to spin in the background or you may end up with huge problems with tracks dropping out when you switch. maybe someone has already thought of this and wrote some script for it.
also would running 2 vdj windows not work? 2 ddecks on one skin and 2 on the other. not sure if that would work but in theory you would just have an overlay.
geposted Sun 02 Jan 11 @ 4:20 pm
not sure what your asking
you can control a 4 deck skin with a 2 deck controller
geposted Sun 02 Jan 11 @ 9:19 pm
He previously designed and created a skin by himself. That skin only has and shows 2 decks.
He would like to know if its possible to turn that skin into a 4 deck skin without writing the xml again from scratch. Like for example swap deck 1&3 on the left side cdj on the skin, if i understand it right
geposted Sun 02 Jan 11 @ 9:39 pm
I'm not sure thats possible. You would need panels for the other 2 decks. Which then you would need to update the XML. I'm no skin master but have created a few in my time. I'm sure someone will come through and clarify this.
Good Luck
Huey
Good Luck
Huey
geposted Sun 02 Jan 11 @ 10:53 pm
yes, that's right. so I need the order for turning deck A into deck C and deck B into deck D.
geposted Mon 03 Jan 11 @ 5:47 am
i completely understand what you guys are saying, but surely theres a way to use an overlay of some sort, so when you hit a button the skin changes or overlays on itself to show the second 2 decks.
it would take a decent bit of programming but theres no reason it cant work.
you could have it with 4 quadrants and a selector switch so which ever decks you select are the ones that appear rather than have deck A and B or deck C and D.
you could have a selector that makes deck A,B,C or D appear at either side depending which selection you use.
man i wish i could programme skins id certainly give it a good go . i reackon it would work too. in theory its just a matter of creating a skin that can be used on either side and is only half the size of the entire window or what ever size you wanted.
see this has me thinking now.
geposted Mon 03 Jan 11 @ 9:06 am
Its already possible, just use the default 6 deck skin...............
Huey
Huey
geposted Mon 03 Jan 11 @ 9:19 am
wow really?
hmmm, so all the hard works been done. just a matter of transferring the code to the personal skin?
would that be about right huey?
geposted Mon 03 Jan 11 @ 9:32 am
Well probably not that easy, lol, you would have to add some graphics but I would say study the XML then give it a try. Also next try asking in the skin forum you might get a better response there.
Huey
Huey
geposted Mon 03 Jan 11 @ 10:28 am
lol, maybe not for us muggles. though for a hardened skin programmer im sure the task wouldnt be a major one. MAYBE! lol
geposted Mon 03 Jan 11 @ 10:51 am
