Hi there
I'm lookink for a skin as the title say with possibilities to use 3 effects and 3 sampler more or less on the main screen; if anybody have an idea wich skin i could use for VJ PRo 7
Thanks
Thanks
geposted Mon 03 Jan 11 @ 2:16 am
My skin, the mix dj pro too much control 4 deck skin can use all 12 samplers, plus it has one effect for each deck which can easily be changed
geposted Mon 03 Jan 11 @ 3:56 pm
Ok thanks but is tit possible to put only 2 deck on the screen?
geposted Tue 04 Jan 11 @ 11:57 am
Sorry but i can t find your skin, would you give me the link pls
Tks
Tks
geposted Sat 22 Jan 11 @ 11:42 pm
well VDJ team wont look into my skin so, here you go https://virtualdj.com/addons/12479/Mix_DJ_Pro_Too_Much_Control_4_Deck.html
i do have to warn you my skin is WAY too colorful, i am working on an improved version of this with not so much colors.
geposted Sun 23 Jan 11 @ 4:04 pm
Ok thanks but im working with 1366 resolution and it doesn t work properly...
geposted Fri 28 Jan 11 @ 10:17 pm
