Forum: Old versions
Topic: Reloop Mixage Controller Edition (LTD)
features:
Professional DJ USB/MIDI controller
Clearly arranged mixer/CD player design for quick and easy access
All controllers in full size
Altogether 54 MIDI controllers (30 buttons, 5 faders, 4 encoders, 1 push knob, 12 knobs, 2 touchsensitive jog wheels)
All MIDI controllers freely assignable
USB bus power: power supply also possible via USB
Anti-theft system: Kensington safety slot
Compatible with Mac OSX and Windows XP/Vista/7
Player section:
- 2 x touchsensitive (adjustable sensitivity), two-part Jog Wheels for scratchingm cueing, etc.
- Large transport section fpr play, cue, cup, and sync (also useable as cue point section)
- 2 different jog modes (scratch & pitch bend, fast search)
- 2 x high resolution 14 bit pitchfader without latch position
- 2 x pitch bend buttons
- 2 x assignable encoders and 4 x buttons for effect and loop control
- Designated knobs for filter and pan effect
- Shift button for double function assignment
- Glistening white, red, and orange LED illumination
geposted Mon 03 Jan 11 @ 9:51 am
Hello,
I would like to buy a device Reloop mixage can you get the drivers for this device.
MAN CAN YOU ALSO SEND ME THE MAPPING PLZ....
Nobody will send you mappings to which you are not currently entitled.
Do not ask this question again or your account will be locked.
Mappers are only available to registered licensed users who have purchased the full VirtualDJ Professional.
Also, the Reloop Mixage is natively supported by the latest version of VirtualDJ, so no mapper needs to be downloaded.
Please download the latest VirtualDJ Home FREE to try it out before purchasing. If you like VirtualDJ, then please support the software and its future development by purchasing it: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it at your gigs.)
