instead of a knob that moves back and forth, to be a bar that lengthens or shortens as the control increases or decreases?
thanks! :)
thanks! :)
geposted Mon 03 Jan 11 @ 2:30 pm
are you wanting to make it yourself or see one in action?
I use sliding "knobs" on a few of my newer skins as opposed to round knobs. It's just a matter of changing the orientation of the <slider> tag from round to vertical or horizontal and doing the graphics correctly.
geposted Mon 03 Jan 11 @ 3:43 pm
well, I think i figured it out, had to use a graphic array...
geposted Mon 03 Jan 11 @ 5:07 pm
yeah, that would work, same technique used for the sliders I came up with to emulate the ones I saw on DjDads touchscreen video preview.
you could also just have the down graphic be the background image and the selected or down image be the full length of the graphic then the bar would appear to grow as the linear slider increased
just a suggestion.
DjChuck
just a suggestion.
DjChuck
geposted Mon 03 Jan 11 @ 6:23 pm
