Do any of you use this skin, https://virtualdj.com/addons/9526/RMX_Style.html, if so do I switch the jogs so I can use them as the effect sliders. In the description on the skin itself says they can be used like that but it doesnt tell me how....................is there a shift button mapped to the RMX that I dont know about?? This skin needs a how to file attatched to it aswell...........Also how are you toggling through the button panels?? Theres like 3 different panels. Yes I'm using this with a Hercules, first time user so any help would be great!!
Huey
Huey
geposted Tue 04 Jan 11 @ 7:06 am
