Hello. (first post here so bear with me ^^)
I got for this Christmas a Hercules Control MP3 e2 system and fell completely in love with it. Been using it...attempting to make mixs here and there along the way.
One problem I have come across is adding the headphones options. I have a 4.1/5.1 surround sound card (not sure but the model is SB Audigy 2 ZS [B000]) and I can't seem to configure my VDJ/Hercules and my computer sound card to play for e.g. Deck A on the speakers and Deck B on my headphones. Any help will be much appreciated. (Must make the point I am a newbie btw ^^)
Thank-you and Happy New Year to all :)
docamixe
docamixe
geposted Tue 04 Jan 11 @ 1:51 pm
In Order to use the headphone previewing mode with Virtual DJ, first check that your sound card’s speaker mode is set to 4-channel or 5.1-channel, using the sound card's own control panel or through Windows SOUND Propterties.
Next, connect your Speakers to the REAR (Black) connector and your headphones to the FRONT (Green) connector on your sound card.
This might seems the opposite of logic , but it actually make sense since the Front connector usually has a stronger signal , which will be appropriate for the headphone.
Finally, in VDJ audio menu, select the following configuration:
- Input : None
- Output(s): Headphone > Master: Rear / headphone: Front
-Soundcard: Your soundcard name here
- Input : None
geposted Wed 05 Jan 11 @ 6:51 am
COULD NOT HAVE PUT IT BETTER MY SELF.
geposted Wed 05 Jan 11 @ 10:36 am
Ah ok, will try that. Thanks :D
geposted Wed 05 Jan 11 @ 12:53 pm
