Here's my problem, I was using VDJ for a while, but then something happened and I had to reinstall. I have a numark omnicontrol controller and when I would use the jog wheels, the left one and right would have different results. The left one would act like any default jog wheel (slowing down the song and creating obvious distortion to the lyrics and then "winding back up" returing to normal), but the right jog wheel would slow down the song, but create no distortion. This created an effect that seemed to draw out whatever word or bass note it was on and then immediately return to normal when released.
I LOVED this. But ever since about two months ago and had to reinstall, both jog wheels act like the norm, and after trying by myself to fix this, I've had zero luck. Please help me get back my right jog wheel!
geposted Wed 05 Jan 11 @ 6:52 pm
hi there, what version are you using?
geposted Wed 05 Jan 11 @ 8:11 pm
7.0 pro. Thinking back, I can't remember if I updated the version when I reinstalled.
geposted Wed 05 Jan 11 @ 8:23 pm
Something to do with the keylock or beatlock settings?
geposted Thu 06 Jan 11 @ 11:47 am
sure you havent got your jogwheel set to scratch mode?
my herc has a button that changes the jogwheel action also check your jog settings n the config
geposted Thu 06 Jan 11 @ 2:20 pm
It's not the beat/keylock, tried. Ive also tried the the other jog wheel modes in that VDJ script. No such luck.
geposted Thu 06 Jan 11 @ 2:28 pm
