Topic: Sampler Devices
Hi there guys...
Just purchased VD7 7 and have no regrets so far.
Anyway, am wondering if anyone can recommend me a good external device to run my sound clips.
The sampler options on VDJ has only 12 options. I use my VDJ as a tool during my emcee jobs.
Can anyone help?
By the way, i am running my VDJ on a Mac Book Pro.
Cheers...
geposted Wed 05 Jan 11 @ 10:36 pm
Look up Jingle Palette, It's software but it works, and it's free.
nice sampler mate! thanks!
any idea how to use this software with VDJ? When i use VDJ with my Hercules MK4 and Jingle Palette at the same time, Jingle Palette wont give a sound. Any idea about the settings?
your jingle palette is on the wrong output
click settings then audio tab then change soundcards in the dropdown til it works .....if it's on the
windows default card unmute it or increase the volume
the built in sampler isn't bad and i think there is a multi bank
plug in now , so you can have more than 12 .....
i sometimes assign trax to preview in the headphones to a button in jingle palette, a useful trick
you can use it for
Thanks! ill try this one.
sorry but isn't 'jingle palette' a windows program....
don't think it will work for me as i ma running a mac.
Actually am looking for something more like an effects box...
where i can load and save my jingles & sound clip... and activate them with a touch of a button...
Roland SP404?
Maybe a Korg NanoKontrol with the sample manager plugin would be a great combo for you. Im doin this from my phone so ill post links when I get home.
Good Day
Huey
i have success using Jingle Palette!
Thanks a man and his music!
thanks for the info guys..
much appreciate....
still a lil' new to all this..
Blulite wrote :
desmond, just use the sample manager plugin you can save multiple banks and just select the one you want for a quick load of a full bank
https://virtualdj.com/addons/1046/Sampler_Manager.html
i was recomended this just the other day and its a cool piece of kit.
thanks but it only has a windows app; while i'm running on OS X... thanks though..
Good Day
Huey
Thanks Huey... will wait for your post :D
