geposted Thu 06 Jan 11 @ 4:40 am
I haven't used those, but I do use the Chauvet D-Fi's. They work well and are easy to use except that there is a very slight delay which is not even really noticeable. Similarly, if you try to do a strobe, the remote units will not quite strobe correctly.
If you (or someone else) does have experience with the Audioworks units, I would be very interested to know if remote strobing works with those, and whether there is a delay.
geposted Thu 06 Jan 11 @ 11:00 am
