I'm looking at trading in my Denon DN-X900 mixer for a DN-MC6000. One feature I love on the Denon DN-X900 mixer is the ability to preset the High/Mid/Low EQ, and then activate the EQ or disable the EQ with the push of the EQ On/Off button on each channel.
I've begun to realize this is not a standard feature on most mixers. Is it possible to do this via a plugin or script within Virtual DJ? Even better would be a single flip switch that resets the eq on one deck at the same time as activating the preset eq on the other deck, and vice versa. I've seen a flip switch like that on some old school hip hop mixers.
geposted Thu 06 Jan 11 @ 11:11 pm
You can't turn the EQ on and off, although you can manipulate it via VDJScript. This means you could toggle and flip the EQ settings, but only with predefined values in the mappers tab.
geposted Fri 07 Jan 11 @ 5:21 am
Not even with a plugin? This seems like something pretty simple to do with the capabilities of Virtual DJ, can I request this feature somehow? What a let down! Grrrr
geposted Fri 07 Jan 11 @ 2:13 pm
