Hi,
I am looking into purchasing two Gemini TT-2000 turntables. They have an RCA out. I have a Hercules MK4 Mixer and a LE Version of VDJ. My mixer has a built in soundcard, and on the back it has two RCA inputs that says (1-2) then (3-4). You can see the back of it here http://www.guitarcenter.com/Hercules-DJ-Console-MK4---Dual-Deck-DJ-Mixer-105915797-i1532211.gc
You can also see the Gemini TT-2000 back here:
http://www.guitarcenter.com/Gemini-TT-2000-Direct-Drive-Turntable-583908-i1480997.gc
Will this work? I am new to turntables (not mixing, but using turntables). Will this work? What will I need to buy for this to work, and what will I need to buy for the Turntables (like the felt things, IDK im new to turntables). Links would be appreciated for things I should consider.
Thanks
Thanks
geposted Sat 08 Jan 11 @ 7:27 pm
Yes they will work, you will need to connect the RCAs from your turntables to the inputs of your MK4 and if the turntables have ground you will need to ground them to your MK4.
A thing to consider is that you cannot do time code vinyl with the bundled LE Version of VDJ, if you want to do this you will need to upgrade to Virtual DJ Pro. The good news is that since you own an MK4 you will get a discount on the upgrade.
geposted Sun 09 Jan 11 @ 11:30 am
Hey, thanks for the response. I figured all that out after 2 hours of research haha. I ended up getting one Numark TT-200, a Serato Scratch cv02 timecode vinyl, and VDJ pro. It works great.
geposted Sun 09 Jan 11 @ 5:21 pm
