Im into upgrade my system.
Have been watching on CROWN XLS 5000 on the internet..
http://www.thomann.de/gb/crown_xls_5000.htm
Do anyone have that amp, and is it good ?
geposted Sun 09 Jan 11 @ 12:40 pm
I saw this amp, very cheap for the power output.
No links but it would probably be last in the chain anyway, go for it.
geposted Sun 09 Jan 11 @ 5:13 pm
Ah,
It looks pretty good, but there are better for cheaper. It also depends what your planning to run it off of.
geposted Tue 11 Jan 11 @ 9:57 pm
Nothing wrong with Crown amps mate but be aware of the 27kg weigh in on this one.
It is a heavy piece of kit and best fitted into a flight case with good strong handles. My only moan with Crown is that the standard handles can make it difficult to lug around.
The QSC PLX 2 and somewhat cheaper GX amps would also be worth a look in this price range.
Daz
Daz
geposted Sat 15 Jan 11 @ 8:40 am
GX7 will power 4 ohm subs and has standard IEC which is a plus just incase you power lead falls out of the back of the van on the way there or something.
geposted Wed 26 Jan 11 @ 6:10 am
