So I'm a noob and want to add to my gear. I wanted to know could you/will you still get them same sound off the RMX with a decent turntable as you would with a battle mixer? Or is the RMX just not cut out to give you that sound when you scratch and so forth?
geposted Sun 09 Jan 11 @ 9:43 pm
The RMX has rather respectable sound for small to medium sized operations. It really depends on which mixer you are referring to.
geposted Sun 09 Jan 11 @ 9:49 pm
Well I just got this RMX and I can say the output is nothing near my mixer. I use an Ecler NUO4 so I guess thats not really fair, lol! For the size it does sound good just wish it was a little louder.
Just my opinion
Huey
Just my opinion
Huey
geposted Sun 09 Jan 11 @ 10:38 pm
No mixer in particular. I just wanted some input from more experience DJ's if you use timecodes with the RMX if you will still achive the same sound as you would with a non midi mixer when you scratch and other TT tricks.
I guess my question is I want to pick a TT up for just scratching reasons, but before I go invest In a $500 plus TT am I just tricking myself(mind) into something I don't need and just invest into a more professional controller?
geposted Mon 10 Jan 11 @ 12:21 am
Any expericened DJ's have any in sight on this?
geposted Mon 10 Jan 11 @ 2:02 pm
About to hook up the rmx to my tables, I'll let you know..............
Huey
Huey
geposted Mon 10 Jan 11 @ 2:06 pm
Well after geting everything hooked up I had a go at it. Now by now means am I a scratch master, lol, but I can pull some flares, chrips and a few others. I do like the short crossfader, if your not careful youll cut to much...........I wish it would put out more sound but I just crank up the system a little more. Heres a screen shot of the settings for the RMX,
And my settings in VDJ,
I'm using Serato timecodes and I dont think its that bad. Give it a try and let me know what you think............
Huey
Huey
geposted Mon 10 Jan 11 @ 5:18 pm
Huey
Huey
Thanks Huey when I get some time I'll hook it up with those settings and if I have any good flares and chirps. I'll post up.
One more thing I'm using a Mac does that matter with also settings?
geposted Tue 11 Jan 11 @ 12:48 am
the sound will be good, but u wont be able to use the xfader for scratching n stuff cuz ti is not as smooth and responsive as regular battle mixers are, since it is midi
geposted Tue 11 Jan 11 @ 8:05 pm
