ok i have been having some crackles and pops with my VMS4 after a ton of tests i found it to work fine on windows 7 with version 6.1 i thought maybe it was because i was on windows 7 instead of XP which i was using with the vms4 before. i checked the version i had on XP and it was 6.1.1. so i returned to my windows 7 partition and installed 6.1.1 to see if the problem appears and sure enough crackles and pops were back with the newer version installed.
i need to TOTALLY wipe vdj and all its components of my system to get back to 6.1 and try it with the vms4 to see if that helps my sound issues. i tried just reinstalling 6.1 over the newer version, which appeared to worked but the crackles are still there.
i know it was on here somewhere before but i can't find it using search.
PLEASE HELP ;)
PLEASE HELP ;)
geposted Tue 11 Jan 11 @ 9:17 am
Just uninstall it the normal way. Then use the registry tool to remove all the registry entries. (found in the DL section)
Greets, Heiko
Greets, Heiko
geposted Tue 11 Jan 11 @ 9:44 am
worked. now just gotta see if the sound issues are there after install. if they are what can i try next to revert to 6.1 that seemed to worked fine in testing today.
geposted Tue 11 Jan 11 @ 10:08 am
damn sound problem is still there? what else can i do to make sure NOTHING from the updated version has been left on my machine?
geposted Tue 11 Jan 11 @ 10:53 am
manquindj has informed me that he tried setting VMS4+timecodes with 7.02 and everything worked fine. So something is wrong with your settings i guess.
geposted Tue 11 Jan 11 @ 11:41 am
then tell me what his settings are exactly cause the only that work for me are 30ms and thats way too high for scratching.
geposted Tue 11 Jan 11 @ 1:56 pm
