Hey kids,
I want to start playing videos in my sets. I have several videos but they don't play. How do I configure video in pro7?
geposted Tue 11 Jan 11 @ 2:00 pm
what hardware and system are you using to display videos mate.
basically what i do is go to diplay settings in your control panel and enable extend display to no 2 screen and size ect close and save.
then go to vdj/video and enable video...then from dropdown box choose use hardware and click oj....always click ok to save changes...
make sure your leads for second display are all connected before enabling in vdj hope this helps
geposted Tue 11 Jan 11 @ 2:08 pm
Right on!! Well that's my first problem is that I don't have the video output set up yet. I was thinking I can play w it in the VDJPro first. But that makes sense. So next question, what do you recommend for set ups? I've look in the market and there are all kinds of options and not sure where to start.
geposted Tue 11 Jan 11 @ 2:42 pm
First your videos have to be in a format that VDJ can handle, which is almost every format; mpeg 1 & 2, mp4, avi, etc. If you are using a second monitor, or projector, it has to be connected before you boot your computer. Adjust your display for extend second monitor in the display menu. In VDJ config, check the activate box in the video tab, and select your video card in the pull-down menu. If you need more help, just ask, we are here to help.
geposted Tue 11 Jan 11 @ 2:44 pm
