When i choose the American Audio Versaport within the setup in VDJ an error message appears that says that my soundcard is not configured correctly or not plugged in. It mentions something about CoreAudio not working as well.
Any solutions?
"Error in the sound driver of CoreAudio. Your soundcard is probably no connected, or the settings are incorrect."
Any solutions?
geposted Tue 11 Jan 11 @ 7:20 pm
What's your settings?
geposted Wed 12 Jan 11 @ 3:47 am
Sorry i'm new here. Should have listed this before
Macbook Pro OS X 10.6.6
2.33ghz, 3gb ram
500gb HD
VDJ 7.0.2 Pro Edition
2.33ghz, 3gb ram
500gb HD
geposted Wed 12 Jan 11 @ 8:08 am
sorry, my fault.
Good to know, but i want to know how your setting is inside VDJ Config -> Soundcard. :-)
geposted Wed 12 Jan 11 @ 8:21 am
Inputs: None
Outputs: Headphones
Master: First card / Headphones: Second card
Sound card: 2 Cards
versaport
Soundblaster Live
Outputs: Headphones
Sound card: 2 Cards
versaport
Soundblaster Live
geposted Wed 12 Jan 11 @ 2:44 pm
Sorry, at the moment i haven't an idea!
The settings are right and the card should also work with Mac.
Hmmm :-(
Did any of your cards work, when you only use one of them?
Hmmm :-(
geposted Fri 14 Jan 11 @ 6:10 am
I have two other soundcards that both work fine. I got the versaport to replace my behringer ucontrol as it does not output at a high enough volume for the club I play at.
I called american audio today and they said the same thing, that it should work. And just for fun I booted into windows and it worked there...so it must be a problem with the Mac driver.
Needless to say, Im disappointed and it will be returned.
Thanks for your help :)
geposted Sat 15 Jan 11 @ 4:18 pm
