I have been unable to get the main volume and the headphone volume to work with mapping. Any help you can provide would be greatly appreciated.
I am running Windows 7 64 bit. I have the beta drivers from Xponent and was running fine with PCDJ VJ, decided to change to Virtual, but the mapping that I downloaded for some reason does not map and will not recognize those two controls.
Thanks
Thanks
geposted Wed 12 Jan 11 @ 8:15 am
By the way, the functions work, the mapping just does not show the changes
geposted Wed 12 Jan 11 @ 8:21 am
As far as I remember, I didn't have to do any changed to the default mapper to get the audio to work.
Make sure you have your both volume (Right next to the mouse pad) turned up, sometimes I would forget to turn this knob and if this isn't sending any volume out, the knobs in your headphone section will not do anything.
geposted Wed 12 Jan 11 @ 1:36 pm
Ive been using my xponent and vdj since 6.x.x. It has always done this with the master.
geposted Thu 13 Jan 11 @ 1:37 am
