I have recently gotten used to beatmatching duplicate songs and some different songs, but I'm looking for more practice. So, recommend me some house/techno with good bass. Similar songs / BPM recommended.
Ex: XXXXXX song AND YYYYYYY song (similar BPM/style)
geposted Wed 12 Jan 11 @ 11:28 am
most dance music is 120-130bpm (beats per minute) so it should not be to hard to find material
geposted Thu 13 Jan 11 @ 4:36 am
Well,depends on. Two tunes you could use is umek - Is it & Umek & Beltek - WE´re not done yet. Same stile,i think is it is around 128 bpm and so is the other tune. Should be fairly easy to beatmatch. If you wish to challange yourelsf,you can use Umek - pravim haos & austin leed - leibowitz
geposted Thu 13 Jan 11 @ 5:12 am
Just look up the track listings of a mix compilation CD (ie Ministry Of Sound annual)... Then have a bash at the mixes yourself.
When you get a bit more into it, maybe have a look at the Mash Up Mix albums and have a go at some of those (may help if your planning to do live remixes)
Hope this helps, I think it's a safe starting point.
Si
Si
geposted Thu 13 Jan 11 @ 5:25 am
practice on VDJ PRO
geposted Thu 13 Jan 11 @ 8:27 am
www.seaham-ravers.co.uk/rave-music-songs
check out the makina section. theres hundreds of tracks you can use.
geposted Thu 13 Jan 11 @ 12:12 pm
