Topic: hooking a mixer up to vdj home version
can you hook the home version of vdj up to a external mixer
geposted Wed 12 Jan 11 @ 7:55 pm
yes
Only for master output.
Home FREE does not support separate deck outputs to an external mixer except during the 10 minute trial of Pro features. It also does not support MIDI controllers or timecode.
Home FREE only supports the following sound configurations:
* Single output using the built-in sound card in your computer (No headphone pre-listening.)
* Master + headphones using a built-in 5.1 surround sound card (Front speaker output for master, rear speaker output for headphones.)
* Master + headphones using the built-in sound card in the computer for master and a basic stereo USB sound card for headphones.
* Master + headphones through the built-in sound card in your computer using the mono split option (NOTE: This will only give you MONO sound.)
For more flexible and advanced sound configuration, such as separate deck outputs to an external audio DJ mixer, timecode or multi-channel DJ sound cards (E.g: Numark DJIO), you will need to purchase either VirtualDJ Basic or VirtualDJ Professional: https://virtualdj.com/products/comparison.html
NOTE: Home FREE is for non-commercial (Unpaid) use at home only.
