Hello,
I cannot update from 7.0 to 7.0.2. I go through the installation, it says that it was installed properly but VDJ still doesn't update itself. What else must a do to update my software?
Thanks
Thanks
geposted Thu 13 Jan 11 @ 10:38 am
Try Keeping Your Database And Trashing The Old And Then Install The New VDJ 7.0.2.
geposted Thu 13 Jan 11 @ 12:29 pm
I believe you only click on the wrong shortcut!
Go to programms and start VDJ from there.
If it works, you have only to replace the icon on the dock.
geposted Fri 14 Jan 11 @ 2:24 am
