HI all, can anyone tell me the config settings to get an external CDJ to run through my RMX... what inputs/outputs etc.
thanx all
Seana
XXX
thanx all
Seana
XXX
geposted Thu 13 Jan 11 @ 1:03 pm
if you want midi control of vdj then just plug in usb and the CDJ will function as a controller. If you want to use timecode CD then plug the audio rca cable into the RMX's input. Make sure that you have the line/phono switch set to line. If you want to use the CDJ's effects and what not though, I'm afraid you would have to run it through an analogue mixer or plug it directly into your speakers.
geposted Thu 13 Jan 11 @ 1:45 pm
Hi babe, thanx 4 the prompt reply.
I've only got Gemini 202's so they haven't got effects or a USB cables to plug in... i've tried to plug the CDJ AV lead into 1&2 input on the RMX but no sound comes out. when i press the source button i just get a continous "brrrrrrrrr" sound but no music...
Im confused...
I really cant get my head round how/what Timecode CDs do... do i need them to use an external CDJ with VDJ?
Seana
XXX
Im confused...
Seana
XXX
geposted Thu 13 Jan 11 @ 3:04 pm
You need to read this first
https://virtualdj.com/wiki/TimeCode%20Config.html
You will also need to download the CD Tmecode from here
https://virtualdj.com/products/timecode/cd.html
geposted Thu 13 Jan 11 @ 5:59 pm
THANX BABE. I'll try that.
Seana
XXX
Seana
XXX
geposted Fri 14 Jan 11 @ 6:38 am
