Im new to downloading add-ons. Im currently using a Mac and I do not know how to actually get the effects into the DJ application. There are .zip files when i download them and when I unzip them i get a folder. Just please tell me how to do this please.
geposted Thu 13 Jan 11 @ 7:46 pm
I have a mac as well. But being that vdj seems to cater to pc rather than mac.....I use bootcamp windows 7. Sorry I couldnt help.
geposted Thu 13 Jan 11 @ 8:00 pm
Wrong they dont "cater"...............most plugins are created by VDJ users and it just so happens that there are more PC users then MAC's. Sorry I'm a PC user so I cant help you.
Huey
P.S. Read this its what you need, https://virtualdj.com/forums/141049/Virtual_DJ_Plugins/How_do_you_put_Plug_Ins_and_Effects_that_I_downloaded_off_website_into_Virtual_Dj_7_.html , and no more double post please...............
Huey
geposted Thu 13 Jan 11 @ 8:04 pm
I'm not to sure but I'm on a mac all I did is download the plug in which Mac then pops up the download box then click on the download and it will ask you to unzip/install then go in, to finder and open up where you have your downloads saved to and then change the format if it's not already done to .vdj and it should pop up as soon as you restart the program. That's how I figured it out. But like I said I'm not to sure since Im new to Mac and only got it use vdj less than a year ago.
Hope that helps.
Hope that helps.
geposted Fri 14 Jan 11 @ 9:22 am
