Hooked up this new Mixtrack to VDJ and it automatically recognizes all buttons and from what I can experiment with, all functions seem to work but I can't get either deck to PLAY? The PLAY, CUE, SYNC e.t.c buttons on both VDJ and Mixtrack all light up but pressing the play button on the Mixtrack and also on VDJ does not play and what's strange now is the VDJ itself without the Mixtrack connected does not play, the only thing I had done prior to connecting the mixtrack was to change the skin and also to remove the external sound card both of which I don't see should have anything to do with the playing of either deck? Help?
geposted Fri 14 Jan 11 @ 4:39 pm
What does it say in the sound card set up, and what soundcard are you using?
geposted Fri 14 Jan 11 @ 5:10 pm
Damn, you are right, so I need to have the external soundcard connected from now for the decks to play, thanks!
geposted Fri 14 Jan 11 @ 5:22 pm
Works with the mixtrack now, I am spinning the wheel but it does not backspin at normal speed, it backspins very slow and this is no matter if a song is playing or paused, any ideas please?
geposted Fri 14 Jan 11 @ 5:28 pm
