Ecco un'altra novità in arrivo da Numark per il 2011, il mini controller DJ 2 GO
Instant DJ performances wherever you go
DJs love to perform but it isn’t always easy to set something up on a moment’s notice. Most DJ software controllers are designed to save DJs from having to lug around crates of vinyl or CDs. Just grab your laptop loaded with your music library, bring your controller and you're off to the gig. However, even the smallest DJ controllers range from being luggable requiring their own set of wheels. Numark has changed all that with DJ2GO. Now for the first time ever, DJs can throw their entire rig into a backpack and have room to spare.
DJ2GO is a portable, affordable and highly capable DJ controller that allows you to control your favorite DJ software with a tactile feel that can’t be matched using a computer mouse and keyboard. DJ2GO weighs just 13 oz. but provides a layout familiar to DJs that includes two platters, a crossfader, pitch and level controls as well as Deck A, Deck B, Master and Headphone gain controls. In addition, you can load and assign tracks to either of the two included deck control sections without ever touching a mouse. Sync and headphone buttons allow you to instantly sync two tracks and monitor either deck section.
Included with DJ2GO is a special edition of Virtual DJ software, designed to mate perfectly with the capabilities of the controller, so you can pick up DJ2GO and literally start performing on the spot. Because DJ2GO is MIDI-compliant, it can be used easily with virtually any DJ software by simply re-mapping the controls in the applicable application. You need only to connect the included USB cable to their Mac or PC and install the software to be up and running.
It doesn't get any easier to set up and perform a set than it is with DJ2GO.
KEY FEATURES
More info: http://www.numark.com/dj2go
KEY FEATURES
- Ultra-portable USB DJ software control for instant gigs
- Compatible with virtually any MIDI-capable DJ application
- Mouseless navigation built in
- Single USB cable provides easy integration with your PC or Mac
- Familiar A/B deck and crossfader make using DJ2GO a snap
- Includes integrated Virtual DJ LE Lite Software
geposted Sat 15 Jan 11 @ 5:40 am
ecco la vera soluzione "minimale" !
Uno di questi + audio2dj e giri il mondo :))))))
geposted Sat 15 Jan 11 @ 7:22 am
davvero carino!!!!
geposted Sat 15 Jan 11 @ 7:35 am
Davvero minimale! Scaffale!
geposted Sat 15 Jan 11 @ 9:46 am
veramente piccolissima!!!! Ma mi viene un dubbio, l'equalizzazione delle tracce come si gestisce???? mi pare che neanche sulla skin ci sia
geposted Sat 15 Jan 11 @ 11:24 am
Salve! avrei una domanda , ho acquistato la numark DJ 2 Go e sarei interessato ad aquistare la licenza home plus per usare illimitatamente la console , io ho un vecchio mac su cui funziona solo la versione 7 di Virtual DJ , volevo sapere..aquistando VD home plus mi verrà fornita solo ed esclusivamente la versione 8 (quindi per me inutilizzabile) oppure verrà integrata con la versione 7? grazie!
geposted Mon 09 Jul 18 @ 8:35 am
A livello generale Virtualdj 7 ormai è fuori catalogo e non più supportato.
Ora tutte le versione in vendita sono basate su Virtualdj 2018
Che sistema operativo è installato nel tuo mac?
geposted Mon 09 Jul 18 @ 10:21 pm
ho un vecchio mac del 2008 e come sistema operativo uso snow leopard perchè l'umico compatibile con quel mac e con logic 7 che uso per le pre registrazioni a casa
geposted Thu 19 Jul 18 @ 7:38 am
Virtualdj 2018 gira su osx 10.7 e superiore
http://it.virtualdj.com/wiki/Requisiti%20minimi%20di%20sistema.html
Virtualdj 7 non è più distribuito e non è più supportato
geposted Thu 19 Jul 18 @ 6:14 pm
