Was wondering if anybody has been able to get the the Virtual box to work properly with vista/win 7 and vdj 7. Or would it be better to reinstall vdj 6.2?
geposted Sun 16 Jan 11 @ 2:05 pm
When I did have it worked great with Vista and VDJ7. What problems are you having??
Huey
Huey
geposted Sun 16 Jan 11 @ 2:30 pm
Just got a new HP with Win 7. For the life of me, I cant get the drivers to load. I get a message saying the driver is not verified, so security wont let me install the driver.
Im using a beta driver of Numarks website.
geposted Mon 17 Jan 11 @ 10:40 am
restart your pc and tap f8 until a menu pops up with the option to disable the driver signature enforcer. disable it and your virtual dj/cue/vinyl program should find your virtual vinyl..........but if you use virtual dj radio, v.7 will not work. use v.6
geposted Fri 11 Feb 11 @ 7:10 am
I had the same problem. To fix mine I reinstalled VV then upgraded again and it worked.
geposted Mon 14 Feb 11 @ 9:52 am
ianmelville, did you get cue v.7 to work with radiodj??
geposted Wed 11 May 11 @ 1:41 pm
sorry you lost me, what is radio dj?
geposted Thu 12 May 11 @ 9:52 am
Disable any Antivrus software you have on your computer first. Disable Firewall too in case it is controlled by windows. then install drivers again.
geposted Thu 12 May 11 @ 9:58 pm
If I am right you have windows 7 64bit OS. If so you are trying to use the 64bit beta drivers for VV or any Numark Beta drivers. The problem with the beta driver is that it has no certificate so windows won’t let you use it. To get it to work you will have to boot windows with certificates disabled, this will let you use the Numark beta drivers. It’s not the best but it’s the only way to get Numark beta drivers to work with windows 7 64bit OS.
It is not the firewall or AV if you have windows 7 64bit OS I had the same thing.
Reboot using advanced start up options and there is an option to turn off signature enoforcement.
Reboot as normal and press F8. Then select " Disable Driver Signature Enforcement". Then install the unsigned driver.
Hope this helps,
Ian
Hope this helps,
Ian
geposted Fri 13 May 11 @ 6:44 am
