How do you save a red unmonitored folder in virtual dj. I created a new folder and put all of my songs I use on a daily basis inside this folder. I now have about 1000 songs in here and want to save to my hard drive in case something happens to virtual dj. It wont let me highlight the songs then drag it over to a new folder. How can I take this folder and save it?
geposted Sun 16 Jan 11 @ 2:09 pm
It is a virtual folder and exists only in the VirtualDJ database.
Putting songs in a virtual folder will not change their physical location on your hard disk. The folder is virtual and the files will remain in their original location on your hard disk.
You should backup your database (My Documents\VirtualDJ\VirtualDJ Database) on a regular basis if the information contained in it is important to you. If using external drives, you should also backup the database found at the root of each drive. Also, please ensure that you backup your entire music collection.
geposted Mon 17 Jan 11 @ 5:53 am
