In front of all my songs I get a yellow + orange question mark.
How can I get rid of this ?
I only want a red mark when this song is played.
I tried to edit the skin, but this doesn't work
geposted Mon 17 Jan 11 @ 4:06 pm
You'll have to edit the BMP file of the skin, not the XML file to achieve something like this.
BTW the yellow question mark means that the file has not been analyzed by VDJ and the orange mark means that the track is out of the current BPM range (thus it won't sync with the active deck)
geposted Mon 17 Jan 11 @ 4:16 pm
I tried to change the skin (bmp): I replaced the orange and yellow icon by the normal one, but no result !
strange :(
Is there a way to analyse al my song in batch (without playing them ?)
I use itunes as archive
strange :(
geposted Mon 17 Jan 11 @ 4:25 pm
Please address to Skin Forum for further assistance. Open a new topic in Skin Forum , by naming the skin you curently use and the modifications you wish to do.
If you wish to analyze a whole folder, click on the folder (left browser side), then click on 1 of the songs in the middle, press Ctr+A to select all files, rightclick and select Scan For BPMs
You can also create a Filter Folder to gather all unscanned files
Filter Name : Unscanned
Filter : isscanned=0
Then you may select ALL or several files from that Filter Folder and select to Scan For BPMs.
geposted Mon 17 Jan 11 @ 4:29 pm
