I have a Numark Mixdeck and Virtual DJ. I used to be a mobile DJ several years ago. I took a break for ten years with family and kids, but I just started again, and am still at the practicing, basement DJ stage currently.
When I try to scratch using music files from the computer, it only scratches on the clockwise, "forward" motion. It is silent on the "backwards", counter-clockwise part of the scratch. I can't do a backspin, because it is silent, and the scratches sound funny too.
However, if I switch the source to "DECK", and have a CD in the Mixdeck, then the scratch works going in both directions, like a scratch should. It works fine if the source is a CD. However, it is a pain to remember to switch my inputs over when I want to scratch, and back to PC when I don't, in addition to running the crossfader, etc.
Why is it only doing half a scratch? :confused:
geposted Tue 18 Jan 11 @ 5:08 am
That's what happens when "Smart Scratch" is enabled. This silences the backwards scratch, I'm guessing your using the Virtual DJ LE software which I am not familiar with but on my version, you go into the scratch tab and make sure the padlock next to "Smart Scratch" is not lit up.
Hope this helps
Si
geposted Tue 18 Jan 11 @ 5:52 am
