Hi everyone
Since 2 years, I have my Hercules DJ RMX console and the virtual dj with it. But I lost the disc of virtual DJ, I'm happy that it's still on my pc. The problem is that my drivers were deleted when my computer crashed and lost many files and programs. So I'm trying to reinstall the drivers. My problem is, when the drivers are installing they ask for a disk that was with my console, I lost that one but the program is still on my pc. How do I solve it so the drivers works fine with my virtual DJ?
geposted Thu 20 Jan 11 @ 1:07 pm
You will have to contact Hercules for a replacement CD.
If you registered your software on this site originally you will have access to VDJ in your download center with the username and password you used to register.
Keith
Keith
geposted Thu 20 Jan 11 @ 1:54 pm
Isn't it possible to fix it without disc? I need it in 2 days, so I don't think that Hercules can help me in 2 days =( Please I hope there is a solution..
geposted Thu 20 Jan 11 @ 2:27 pm
You can get the latest driver directly from the support site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=1
As for the installation problem you are having, try this:
Download and run the new driver package. It should normally uninstall the previous driver version. if this works, you will need to run it again to install the new driver, following these instructions TO THE LETTER!
http://ts.hercules.com/download/sound/txt/DJ_Series_INSTALLATION_PC_EN.pdf
Does this work ?
Does this work ?
geposted Fri 21 Jan 11 @ 6:06 am
