Hi
I'm new to Virtual DJ. Just began to try it out to see if it fits me or not. I'm using SSL for club gigs, but as Serato has no HID support for the 350's I'm looking for an alternative software to use at home.
So here's my question: is it very hard to remap one or two buttons on the 350's? What i'd like to do for example is use 'playlist' button on the CDJ to trigger effects on or off and maybe use 'bpm lock' button to trigger 'sync' in the software.
Thanks.
Thanks.
geposted Fri 21 Jan 11 @ 2:45 am
Mapping is not hard to do - Please see http://www.virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html
The actions that you would need to map are:
effect active
sync
(Or effect "Name" active is you wish to activate a specific effect.)
effect active
sync
geposted Fri 21 Jan 11 @ 12:29 pm
It's not hard. Check on Youtube, there's tons of tutorials on there that have step by step walk throughs on how to MIDI map VDJ to many different devices.
geposted Fri 21 Jan 11 @ 1:07 pm
