Hey, I've got a wedding coming up in a few months and the bride and groom want a mix of 3 songs that they are going to have some choreography figured out to. They want a copy of the exact mix that I will play at the reception. I thought there was a way to do this in VDJ7 but I've been looking through the configurations and I can't find how to record.
I need it recorded and saved as an mp3 so I can give it to them and then so I can play it at the reception.
What is the best way to do this?
Thanks in advance
Thanks in advance
geposted Fri 21 Jan 11 @ 12:43 pm
mate go to record under your browser bar.
click on audio record...
open config and name your mp3
now record your mix when done go to my documents and your mix should be ther hope this helps
i always do a mock mix first to make sure it works
geposted Fri 21 Jan 11 @ 12:59 pm
Oh man, thank you! I knew I saw it somewhere.
Worked perfect, client is happy
geposted Fri 21 Jan 11 @ 2:39 pm
